RhinoInside.Revit.dll reference no longer in Rhino Inside Revit add in directory
Now that I installed the latest RIR I am not able to find the
RhinoInside.Revit.dll reference it used to be in the
C:\Users\USERNAME\AppData\Roaming\Autodesk\Revit\Addins\2020\RhinoInside.Revit
Where could I find this .dll to make custom C# nodes?
Thanks
ok i found it looks like you moved it to the
C:\ProgramData\Autodesk\Revit\Addins\2020\RhinoInside.Revit\RhinoInside.Revit.dll
Location?
will it live there from now on?
We have this pending issue that should fix this for you.
But by now yes this will be the location.
