RhinoCommon: Set Dark Theme
Is there a way to set the dark theme by code?
Thanks,
Hi @rafadelmolino,
The Options command can be scripted.
_-Options _Appearance _Colors _Dark _EnterEnd
– Dale
Hi Rafael,
Below a piece of code I use to do some settings. I’ve added a viewport color setting as example for you.
try
                Rhino.ApplicationSettings.AppearanceSettings.ShowSideBar = false;
                Rhino.ApplicationSettings.ModelAidSettings.NudgeMode = 2;
                Rhino.ApplicationSettings.ModelAidSettings.NudgeKeyStep = 1;
                Rhino.ApplicationSettings.ModelAidSettings.CtrlNudgeKeyStep = 3;
                Rhino.ApplicationSettings.ModelAidSettings.ShiftNudgeKeyStep = 5;
                Rhino.ApplicationSettings.AppearanceSettings.ShowCrosshairs = true;
                Rhino.ApplicationSettings.AppearanceSettings.ViewportBackgroundColor = System.Drawing.Color.AliceBlue;
                //format folderpath for source file
                string folderPath = "PluginData\\PLTTemplate\\";
                string templatePLTPlugin = Path.Combine(Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location), folderPath, "PLT Template V01EN.3dm");
                //Check if grasshopper file exists
                if (File.Exists(templatePLTPlugin) == false)
                    return Result.Failure;
                //set template if isnt equal to the plttemplate
                string currentTemplate = Rhino.ApplicationSettings.FileSettings.TemplateFile;
                    if (!currentTemplate.Equals(templatePLTPlugin))
                        Rhino.ApplicationSettings.FileSettings.TemplateFile = templatePLTPlugin;
                return Result.Success;
