Hi there,
I know this is to be found in a lot of discussions.
I am trying to join two breps by using Brep.CreateBooleanUnion().
Even though I use this:
for p in lst:
p.Faces.SplitKinkyFaces(Rhino.RhinoMath.DefaultAngleTolerance, True)
if BrepSolidOrientation.Inward == p.SolidOrientation:
p.Flip()
It is not working.
Doing this manually works perfectly fine, though.
I even increased the tolerance in the method…
Then I just added the elments to the document and tried:
import System
objs = rs.GetObjects()
breps = [rs.coercegeometry(x) for x in objs]
breps = System.Array[Brep](breps)
test = Brep.CreateBooleanUnion(breps, tol_abs)[0]
sc.doc.Objects.Add(test)
The result is successful and I get the brep.
What might be wrong in my initial script so this won’t work?
Any ideas?
Thanks,
T.
