RhinoCommon - CommandPromptPosition
Hi guys,
In Rhino 6 I’m trying to move the command prompt in my skin to the bottom part of the window but it does not work, I’m using:
AppearanceSettings.CommandPromptPosition = CommandPromptPosition.Bottom;
I tried calling it from this skin methods:
  • OnEndLoadAtStartPlugIns
  • RhinoApp.Initialized event
I also tried to call it from my plugin with same results:
  • OnLoad
In Rhino 5 it works if i use the RhinoApp.Initialized event. Do you know how to solve this in Rhino 6?
Regards
Hi @mpcarlos87,
We’re looking into this.
– Dale
Thanks!
Can you try deleting your %appdata%\McNeel\Rhinoceros\6.0\settings\settings-Scheme_[skin scheme name]* files and tell me if it works then? I think I understand what is going on and am able to make it work on my local machine after deleting these files.
I logged this as RH-42198 and am working on a fix.
Hi @JohnM,
Thank you, I tested it and it works fine (I also deleted window_positions-Scheme…). Let me know if you need to check any other behavior!
By the way I don’t have access to the Issue :smiley:
Regards,
I made the issue public and have checked in a fix. This should be resolved in the next public release.
Thanks!
RH-42198 is fixed in the latest WIP
