Attempting to install Rhino gives the following error:
Summary
Redist_VC2015:-2147023728
>>>> C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053.log
[15AD4:F4B0][2025-03-17T16:20:53]i001: Burn v3.11.100.14911, Windows v10.0 (Build 26100: Service Pack 0), path: C:\Users\XXXX\AppData\Local\Temp\{B54B3A1E-3DD6-43BC-B883-FDEBAA4FF35C}\.cr\rhino_en-us_8.17.25066.07001.exe
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'BundleVersion' to value '8.17.25066.07001'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'CUSTOMER_NAME' to value ''
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'COMPANY_NAME' to value ''
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'INSTALLDIR' to value ''
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'LICENSE_METHOD' to value ''
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing hidden variable 'LICENSE_KEY'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing hidden variable 'LICENSE_VALIDATION_CODE'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'ZOO_SERVER' to value ''
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'DISABLE_INTERNET_ACCESS' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'ENABLE_AUTOMATIC_UPDATES' to value '1'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'SEND_STATISTICS' to value '1'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'RegistryRoot' to value 'Software\McNeel\Rhinoceros\8.0\Install'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'FolderName' to value 'Rhino 8'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'IgnoreFolderName' to value 'Rhino 8 WIP'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'CheckNETRuntime_Framework' to value 'Microsoft.WindowsDesktop.App'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'CheckNETRuntime_Version' to value '7.0.0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'CheckNETRuntime_RollForwardPolicy' to value 'LatestPatch'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing string variable 'CheckNETRuntime_Result' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_EN' to value '1'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_FR' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_IT' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_DE' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_ES' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_KO' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_JA' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_TW' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_CN' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_PL' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_CS' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_PT' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Initializing numeric variable 'INSTALL_RU' to value '0'
[15AD4:F4B0][2025-03-17T16:20:53]i009: Command Line: '-burn.clean.room=C:\Users\XXXX\Downloads\rhino_en-us_8.17.25066.07001.exe -burn.filehandle.attached=656 -burn.filehandle.self=648'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\XXXX\Downloads\rhino_en-us_8.17.25066.07001.exe'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\XXXX\Downloads\'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053.log'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Setting string variable 'WixBundleName' to value 'Rhino 8'
[15AD4:F4B0][2025-03-17T16:20:53]i000: Setting string variable 'WixBundleManufacturer' to value 'Robert McNeel & Associates'
[15AD4:F4B0][2025-03-17T16:20:54]i100: Detect begin, 19 packages
[15AD4:12E6C][2025-03-17T16:20:54]i000: OnInitializeLayout
[15AD4:12E6C][2025-03-17T16:20:54]i000: PrivateDetect Begin
[15AD4:12E6C][2025-03-17T16:20:54]i000: Failed to open license file: 'C:\ProgramData\McNeel\Rhinoceros\6.0\License Manager\Licenses\55500d41-3a41-4474-99b3-684032a4f4df.lic'
[15AD4:12E6C][2025-03-17T16:20:54]i000: PrivateDetectNetCoreRuntime Begin
[15AD4:12E6C][2025-03-17T16:20:54]i000: netcorecheck_path: C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.ba\helpers\NetCoreCheck.exe
[15AD4:12E6C][2025-03-17T16:20:54]i000: CheckNETRuntime_Framework: Microsoft.WindowsDesktop.App
[15AD4:12E6C][2025-03-17T16:20:54]i000: CheckNETRuntime_Version: 7.0.0
[15AD4:12E6C][2025-03-17T16:20:54]i000: CheckNETRuntime_RollForwardPolicy: LatestPatch
[15AD4:12E6C][2025-03-17T16:20:54]i000: Setting string variable 'CheckNETRuntime_Result' to value '0'
[15AD4:12E6C][2025-03-17T16:20:54]i000: PrivateDetectNetCoreRuntime End
[15AD4:12E6C][2025-03-17T16:20:54]i000: GetSystemDefaultLangID() returned 2057
[15AD4:12E6C][2025-03-17T16:20:54]i000: GetUserDefaultLangID() returned 3081
[15AD4:12E6C][2025-03-17T16:20:54]i000: GetOsLanguage() returned en
[15AD4:12E6C][2025-03-17T16:20:54]i000: version_NT64 = 10.0.0.0; service_pack =
[15AD4:12E6C][2025-03-17T16:20:54]i000: Comparing ver_64 (10.0.0.0) to ver_win_10 (10.0.0.0)
[15AD4:12E6C][2025-03-17T16:20:54]i000: ver_64 >= ver_win_10
[15AD4:12E6C][2025-03-17T16:20:54]i000: Showing UI from C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.ba\en\welcome.htm
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting version variable 'WUAUENG_FILEVERSION' to value '1309.2410.30012.0'
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'ReadDisableInternetAccess' evaluates to false.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting numeric variable 'VC2010_exists' to value 1
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'NOT INSTALLDIR' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'INSTALLDIR' to value 'C:\Program Files\Rhino 8\'
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'VC2015_build' to value '34433'
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting numeric variable 'VC2013_exists' to value 1
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'MSWebView2_Standalone_version' to value '133.0.3065.92'
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting numeric variable 'ReadDisableInternetAccess' to value 1
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'NOT ZOO_SERVER' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Registry key not found. Key = 'SOFTWARE\McNeel\Rhinoceros\6.0\License Manager'
[15AD4:F4B0][2025-03-17T16:20:54]i000: Unsetting variable 'ZOO_SERVER'
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'VC2013_version' to value '12.0.30501.0'
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting numeric variable 'MSWebView2_Standalone_exists' to value 1
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'NOT SEND_STATISTICS' evaluates to false.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Registry key not found. Key = 'SOFTWARE\McNeel\Rhinoceros\8.0\License Manager'
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'NOT CUSTOMER_NAME' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'CUSTOMER_NAME' to value ''
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting numeric variable 'VC2015_exists' to value 1
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting numeric variable 'ReadEnableUpdatesKey' to value 1
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'VC2010_build' to value '167812379'
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'ReadEnableUpdatesKey' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'ENABLE_AUTOMATIC_UPDATES' to value '0'
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'NOT COMPANY_NAME' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'COMPANY_NAME' to value ''
[15AD4:F4B0][2025-03-17T16:20:54]i102: Detected related bundle: {4f9ca02d-7d58-42f1-8701-cc8993c96365}, type: Upgrade, scope: PerMachine, version: 8.14.24345.15001, operation: MajorUpgrade
[15AD4:12E6C][2025-03-17T16:20:54]i000: Checking for updates at URL https://www.rhino3d.com/feeds/installer/?product=rhino&version=8.17.25066.07001&edition=commercial&locale=en-us
[15AD4:F4B0][2025-03-17T16:20:54]e000: Error 0x80070002: Failed attempt to download update feed from URL: 'https://www.rhino3d.com/feeds/installer/?product=rhino&version=8.17.25066.07001&edition=commercial&locale=en-us' to: 'C:\Users\XXXX\AppData\Local\Temp\UpdateFeed_20250317162054.xml'
[15AD4:F4B0][2025-03-17T16:20:54]e000: Error 0x80070002: Failed to download update feed.
[15AD4:F4B0][2025-03-17T16:20:54]e000: Error 0x80070002: Failed to detect atom feed update.
[15AD4:F4B0][2025-03-17T16:20:54]e000: Error 0x80070002: Failed to detect update.
[15AD4:F4B0][2025-03-17T16:20:54]i199: Detect complete, result: 0x80070002
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'ReadDisableInternetAccess' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i000: Setting string variable 'DISABLE_INTERNET_ACCESS' to value '0'
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'NOT INSTALLDIR' evaluates to false.
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'VC2013_exists=1 AND VC2013_version>=v12.0.30501.0' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'VC2015_exists=1 AND VC2015_build>=34438' evaluates to false.
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'MSWebView2_Standalone_exists=1 AND MSWebView2_Standalone_version>=v116.0.1938.0' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i052: Condition 'CheckNETRuntime_Result=0' evaluates to true.
[15AD4:F4B0][2025-03-17T16:20:54]i103: Detected related package: {226CE350-356A-4B89-AD18-7EBB63B3087C}, scope: PerMachine, version: 8.14.24345.15001, language: 0 operation: MajorUpgrade
[15AD4:F4B0][2025-03-17T16:20:54]i103: Detected related package: {46357055-050C-44F7-9654-2ADBB6807618}, scope: PerMachine, version: 9.0.25043.12305, language: 0 operation: Downgrade
[15AD4:F4B0][2025-03-17T16:20:54]i103: Detected related package: {F9BF579C-54D4-451A-9D91-FF5B23047B3B}, scope: PerMachine, version: 8.14.24345.15001, language: 0 operation: MajorUpgrade
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: Redist_VC2013, state: Present, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: Redist_VC2015, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: Redist_MSWebView2_Standalone, state: Present, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: Redist_NetCore_WindowsDesktop_Runtime, state: Present, cached: Complete
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: rhino.msi, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: rhiexec.msi, state: Obsolete, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: en_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: fr_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: it_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: de_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: es_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: ko_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: ja_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: tw_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: cn_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: pl_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: cs_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: pt_lang_pack, state: Absent, cached: None
[15AD4:F4B0][2025-03-17T16:20:54]i101: Detected package: ru_lang_pack, state: Absent, cached: None
[15AD4:12E6C][2025-03-17T16:20:54]i000: windowsUpdateRequired: ver_NT64 = '10.0.0.0'
[15AD4:12E6C][2025-03-17T16:20:54]i000: Showing UI from C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.ba\en\install.htm
[15AD4:F4B0][2025-03-17T16:20:54]i199: Detect complete, result: 0x0
[15AD4:12E6C][2025-03-17T16:21:21]i000: GetSystemDefaultLangID() returned 2057
[15AD4:12E6C][2025-03-17T16:21:21]i000: GetUserDefaultLangID() returned 3081
[15AD4:12E6C][2025-03-17T16:21:21]i000: GetOsLanguage() returned en
[15AD4:12E6C][2025-03-17T16:21:21]i000: version_NT64 = 10.0.0.0; service_pack =
[15AD4:12E6C][2025-03-17T16:21:21]i000: Comparing ver_64 (10.0.0.0) to ver_win_10 (10.0.0.0)
[15AD4:12E6C][2025-03-17T16:21:21]i000: ver_64 >= ver_win_10
[15AD4:12E6C][2025-03-17T16:21:21]i000: Showing UI from C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.ba\en\install_advanced.htm
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting hidden variable 'LICENSE_KEY'
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting string variable 'CUSTOMER_NAME' to value ''
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting string variable 'COMPANY_NAME' to value ''
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting string variable 'INSTALLDIR' to value 'C:\Program Files\Rhino 8\'
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'SEND_STATISTICS' to value 1
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'ENABLE_AUTOMATIC_UPDATES' to value 1
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'DISABLE_INTERNET_ACCESS' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_EN' to value 1
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_FR' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_IT' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_DE' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_ES' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_KO' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_JA' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_TW' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_CN' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_PL' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_CS' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_PT' to value 0
[15AD4:12E6C][2025-03-17T16:22:51]i000: Setting numeric variable 'INSTALL_RU' to value 0
[15AD4:F4B0][2025-03-17T16:22:51]i200: Plan begin, 19 packages, action: Install
[15AD4:F4B0][2025-03-17T16:22:51]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2013
[15AD4:F4B0][2025-03-17T16:22:51]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2015
[15AD4:F4B0][2025-03-17T16:22:51]i000: Setting string variable 'WixBundleLog_Redist_VC2015' to value 'C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053_000_Redist_VC2015.log'
[15AD4:F4B0][2025-03-17T16:22:51]w321: Skipping dependency registration on package with no dependency providers: Redist_MSWebView2_Standalone
[15AD4:F4B0][2025-03-17T16:22:51]w321: Skipping dependency registration on package with no dependency providers: Redist_NetCore_WindowsDesktop_Runtime
[15AD4:F4B0][2025-03-17T16:22:51]i000: Setting string variable 'WixBundleRollbackLog_rhino.msi' to value 'C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053_001_rhino.msi_rollback.log'
[15AD4:F4B0][2025-03-17T16:22:51]i000: Setting string variable 'WixBundleLog_rhino.msi' to value 'C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053_001_rhino.msi.log'
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_EN=1' evaluates to true.
[15AD4:F4B0][2025-03-17T16:22:51]i000: Setting string variable 'WixBundleRollbackLog_en_lang_pack' to value 'C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053_002_en_lang_pack_rollback.log'
[15AD4:F4B0][2025-03-17T16:22:51]i000: Setting string variable 'WixBundleLog_en_lang_pack' to value 'C:\Users\XXXX\AppData\Local\Temp\Rhino_8_20250317162053_002_en_lang_pack.log'
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_FR=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_IT=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_DE=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_ES=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_KO=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_JA=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_TW=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_CN=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_PL=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_CS=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_PT=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i052: Condition 'INSTALL_RU=1' evaluates to false.
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: Redist_VC2013, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: Redist_VC2015, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: Redist_MSWebView2_Standalone, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: Redist_NetCore_WindowsDesktop_Runtime, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: rhino.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: rhiexec.msi, state: Obsolete, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: en_lang_pack, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: fr_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: it_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: de_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: es_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: ko_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: ja_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: tw_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: cn_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: pl_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: cs_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: pt_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i201: Planned package: ru_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[15AD4:F4B0][2025-03-17T16:22:51]i207: Planned related bundle: {4f9ca02d-7d58-42f1-8701-cc8993c96365}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[15AD4:12E6C][2025-03-17T16:22:52]i000: GetSystemDefaultLangID() returned 2057
[15AD4:12E6C][2025-03-17T16:22:52]i000: GetUserDefaultLangID() returned 3081
[15AD4:12E6C][2025-03-17T16:22:52]i000: GetOsLanguage() returned en
[15AD4:12E6C][2025-03-17T16:22:52]i000: version_NT64 = 10.0.0.0; service_pack =
[15AD4:12E6C][2025-03-17T16:22:52]i000: Comparing ver_64 (10.0.0.0) to ver_win_10 (10.0.0.0)
[15AD4:12E6C][2025-03-17T16:22:52]i000: ver_64 >= ver_win_10
[15AD4:12E6C][2025-03-17T16:22:52]i000: Showing UI from C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.ba\en\progress.htm
[15AD4:F4B0][2025-03-17T16:22:52]i299: Plan complete, result: 0x0
[15AD4:F4B0][2025-03-17T16:22:52]i300: Apply begin
[15AD4:F4B0][2025-03-17T16:22:52]i010: Launching elevated engine process.
[15AD4:F4B0][2025-03-17T16:22:54]i011: Launched elevated engine process.
[15AD4:F4B0][2025-03-17T16:22:54]i012: Connected to elevated engine.
[1C1DC:101C0][2025-03-17T16:22:54]i358: Pausing automatic updates.
[1C1DC:101C0][2025-03-17T16:22:54]i359: Paused automatic updates.
[1C1DC:101C0][2025-03-17T16:22:54]i360: Creating a system restore point.
[1C1DC:101C0][2025-03-17T16:23:01]i361: Created a system restore point.
[1C1DC:101C0][2025-03-17T16:23:01]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{939b3545-5a6e-4655-8f84-3ef73b53267b}, options: 0x7, disable resume: No
[1C1DC:101C0][2025-03-17T16:23:01]i000: Caching bundle from: 'C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.be\Bootstrapper.exe' to: 'C:\ProgramData\Package Cache\{939b3545-5a6e-4655-8f84-3ef73b53267b}\Bootstrapper.exe'
[1C1DC:101C0][2025-03-17T16:23:01]i320: Registering bundle dependency provider: {939b3545-5a6e-4655-8f84-3ef73b53267b}, version: 8.17.25066.7001
[1C1DC:101C0][2025-03-17T16:23:01]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{939b3545-5a6e-4655-8f84-3ef73b53267b}, resume: Active, restart initiated: No, disable resume: No
[15AD4:13F98][2025-03-17T16:23:01]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, copy from: C:\Users\XXXX\Downloads\redist\VC2022_redist_x64.exe
[15AD4:13F98][2025-03-17T16:23:01]i000: Setting string variable 'WixBundleLastUsedSource' to value 'C:\Users\XXXX\Downloads\'
[1C1DC:19AF8][2025-03-17T16:23:01]e000: Error 0x80070490: Failed to find expected public key in certificate chain.
[1C1DC:19AF8][2025-03-17T16:23:01]e000: Error 0x80070490: Failed to verify expected payload against actual certificate chain.
[1C1DC:19AF8][2025-03-17T16:23:01]e000: Error 0x80070490: Failed to verify signature of payload: Redist_VC2015
[1C1DC:19AF8][2025-03-17T16:23:01]e310: Failed to verify payload: Redist_VC2015 at path: C:\ProgramData\Package Cache\.unverified\Redist_VC2015, error: 0x80070490. Deleting file.
[1C1DC:19AF8][2025-03-17T16:23:01]e000: Error 0x80070490: Failed to cache payload: Redist_VC2015
[15AD4:13F98][2025-03-17T16:23:01]e314: Failed to cache payload: Redist_VC2015 from working path: C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\Redist_VC2015, error: 0x80070490.
[15AD4:13F98][2025-03-17T16:23:01]e349: Application requested retry of payload: Redist_VC2015, encountered error: 0x80070490. Retrying...
[15AD4:13F98][2025-03-17T16:23:04]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, copy from: C:\Users\XXXX\Downloads\redist\VC2022_redist_x64.exe
[1C1DC:19AF8][2025-03-17T16:23:04]e000: Error 0x80070490: Failed to find expected public key in certificate chain.
[1C1DC:19AF8][2025-03-17T16:23:04]e000: Error 0x80070490: Failed to verify expected payload against actual certificate chain.
[1C1DC:19AF8][2025-03-17T16:23:04]e000: Error 0x80070490: Failed to verify signature of payload: Redist_VC2015
[1C1DC:19AF8][2025-03-17T16:23:04]e310: Failed to verify payload: Redist_VC2015 at path: C:\ProgramData\Package Cache\.unverified\Redist_VC2015, error: 0x80070490. Deleting file.
[1C1DC:19AF8][2025-03-17T16:23:04]e000: Error 0x80070490: Failed to cache payload: Redist_VC2015
[15AD4:13F98][2025-03-17T16:23:04]e314: Failed to cache payload: Redist_VC2015 from working path: C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\Redist_VC2015, error: 0x80070490.
[15AD4:13F98][2025-03-17T16:23:04]e349: Application requested retry of payload: Redist_VC2015, encountered error: 0x80070490. Retrying...
[15AD4:13F98][2025-03-17T16:23:07]i338: Acquiring package: Redist_VC2015, payload: Redist_VC2015, copy from: C:\Users\XXXX\Downloads\redist\VC2022_redist_x64.exe
[1C1DC:19AF8][2025-03-17T16:23:07]e000: Error 0x80070490: Failed to find expected public key in certificate chain.
[1C1DC:19AF8][2025-03-17T16:23:07]e000: Error 0x80070490: Failed to verify expected payload against actual certificate chain.
[1C1DC:19AF8][2025-03-17T16:23:07]e000: Error 0x80070490: Failed to verify signature of payload: Redist_VC2015
[1C1DC:19AF8][2025-03-17T16:23:07]e310: Failed to verify payload: Redist_VC2015 at path: C:\ProgramData\Package Cache\.unverified\Redist_VC2015, error: 0x80070490. Deleting file.
[1C1DC:19AF8][2025-03-17T16:23:07]e000: Error 0x80070490: Failed to cache payload: Redist_VC2015
[15AD4:13F98][2025-03-17T16:23:07]e314: Failed to cache payload: Redist_VC2015 from working path: C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\Redist_VC2015, error: 0x80070490.
[15AD4:F4B0][2025-03-17T16:23:07]e000: Error 0x80070490: Failed while caching, aborting execution.
[1C1DC:101C0][2025-03-17T16:23:07]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{939b3545-5a6e-4655-8f84-3ef73b53267b}, resume: None, restart: None, disable resume: No
[1C1DC:101C0][2025-03-17T16:23:07]i330: Removed bundle dependency provider: {939b3545-5a6e-4655-8f84-3ef73b53267b}
[1C1DC:101C0][2025-03-17T16:23:07]i352: Removing cached bundle: {939b3545-5a6e-4655-8f84-3ef73b53267b}, from path: C:\ProgramData\Package Cache\{939b3545-5a6e-4655-8f84-3ef73b53267b}\
[1C1DC:101C0][2025-03-17T16:23:07]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{939b3545-5a6e-4655-8f84-3ef73b53267b}, resume: None, restart initiated: No, disable resume: No
[15AD4:F4B0][2025-03-17T16:23:07]i399: Apply complete, result: 0x80070490, restart: None, ba requested restart: No
[15AD4:12E6C][2025-03-17T16:23:07]i000: >>>>>> DOWNLOAD CACHE FAILURE <<<<<<
[15AD4:12E6C][2025-03-17T16:23:07]i000: GetSystemDefaultLangID() returned 2057
[15AD4:12E6C][2025-03-17T16:23:07]i000: GetUserDefaultLangID() returned 3081
[15AD4:12E6C][2025-03-17T16:23:07]i000: GetOsLanguage() returned en
[15AD4:12E6C][2025-03-17T16:23:07]i000: version_NT64 = 10.0.0.0; service_pack =
[15AD4:12E6C][2025-03-17T16:23:07]i000: Comparing ver_64 (10.0.0.0) to ver_win_10 (10.0.0.0)
[15AD4:12E6C][2025-03-17T16:23:07]i000: ver_64 >= ver_win_10
[15AD4:12E6C][2025-03-17T16:23:07]i000: Showing UI from C:\Users\XXXX\AppData\Local\Temp\{D0D8DAA7-FE4E-4ABC-A368-F7A5241469BB}\.ba\en\download_failed.htm
Actually, looking at the log further, it is complaining about not being able to verify the VC2022_redist_x64.exe in Downloads\redist. (see my next comment below)
This also seems to be the case for the current WIP installer.
