Is there a way to run the Selective Clipping added in Rhino 8 from a script?
I want to clip only specified objects.
The Clipping Plane Geometry has a SetClipParticipation and GetClipParticipation method along with a bool toggle ParticipationListsEnabled
Using these 3 together you can query a clipping plane for its list of objects/layers as well as set them and then toggle those lists active/inactive.
Here’s a simple example of their usage.
import Rhino
import scriptcontext as sc
def pick_clipping_plane_and_filter_objects():
# Prompt to pick a clipping plane
go = Rhino.Input.Custom.GetObject()
go.GeometryFilter = Rhino.DocObjects.ObjectType.ClipPlane
go.SetCommandPrompt("Select clipping plane")
go.EnableUnselectObjectsOnExit(True)
go.Get()
if go.Result() != Rhino.Input.GetResult.Object:
return
# Make sure we have a valid clipping plane object
cp = go.Object(0).Object()
if cp is None or not isinstance(cp, Rhino.DocObjects.ClippingPlaneObject):
return
# Pick some objects to exclude
go.EnablePreSelect(False, True)
go.SetCommandPrompt("Select objects to filter")
go.GeometryFilter = Rhino.DocObjects.ObjectType.AnyObject
go.GetMultiple(0, 0)
return
# Grab the ids of the objects to exclude
selected_object_ids = [o.ObjectId for o in go.Objects()]
# Enable the clipping list
cp.ClippingPlaneGeometry.ParticipationListsEnabled = True
# Set any object ids or layer indices into the clip lists and toggle the IsExclusion bool
cp.ClippingPlaneGeometry.SetClipParticipation(selected_object_ids, None, True)
# Commit the changes
cp.CommitChanges()
# Query the clipping plane object for its existing list of objects and layers
object_ids, layer_indices, is_exclusion_list = cp.ClippingPlaneGeometry.GetClipParticipation()
print("object count: {}".format(len(object_ids)))
print("layer count: {}".format(len(layer_indices)))
print("is exclusion list {}".format(is_exclusion_list))
if __name__ == "__main__":
Thanks for the response!
It worked.
I was looking inside ClippingPlaneObject, but I see that there is a separate ClippingPlaneSurfaceClass!
Thank you.
