I’m on Rhino 8 for Mac using the Script Editor. There doesn’t seem to be a menu command for formatting selected lines as comment or uncomment. Are there key commands for this? Will this feature return to the script editor?
Thanks!
-Jim
Thanks!
-Jim
CMD + / used to work in Rhino 8.3, but it seems to be broken now or they changed it to something else.
@Judith_Fitzgibbon We do have those shortcuts but there seems to be a bug with the editor swallowing the shortcuts and not executing the commands. Here is a few YTs related to shortcuts on macOS we are working on:
One issue could be that on my Swiss keyboard, the / is located above the 7, which means that for the shortcut I need to press cmd + shift + 7, but it doesn’t work with the other /-only key from above the number block of the keyboard either.
