I noticed that Rhino 8 is treating clipping plane intersections differently from Rhino 7.
The following is a partial hull surface, so it’s got some complex curvature, but it’s nothing too crazy, (I think).
There are two clipping planes active on it (shown in Magenta and Red), which is how we might show a deck plan view in an arrangement drawing.
In Rhino, 7, everything works just fine:
In Rhino 8, it’s hardly identifying an intersection at all:
It’s only acting like this to this surface and it’s mirror across the centerline. Joining/re-meshing, etc. does not yield any different results. Tweaking clipping section styles doesn’t change anything, nor does using the new clipping depth on a single clipping plane…
…In fact, using clipping depth makes the clipping intersections on the “far side” (opposing plane to the clipping plane object) appear THROUGH the model, like they’re being X-rayed:
I had a colleague reproduce the results with the same file.
He also noticed that exporting the surface as a STEP makes the clipping intersections magically work while it’s blocked, and then stops working once exploded to a surface. It also seems to display intersections properly while the clipping plane is moving mid-command, but once you accept the new position, the intersections disappear again:
Rhino file to test:
Clipping Plane Intersection Issue.3dm (122.4 KB)
Rhino Specs:
Version 8 SR4
(8.4.24030.15001, 2024-01-30)
Commercial
SN: 6-1802-0101-1-11759-11090
Windows User, Glosten, Inc.
SystemInfo:
Rhino 8 SR4 2024-1-30 (Rhino 8, 8.4.24030.15001, Git hash:master @ 97577baf4e4ae40c7f2ed3ef4e802db24f2e82ae)
License type: Commercial, build 2024-01-30
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 8-11-2023 (M-D-Y).
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 16GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\export_GHS.rhp “General Hydrostatics (GHS) Export”
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.4.24030.15001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
