BUG: clipping plane intersection lines color dont respect setting
clipped geometry (cut):
i dont see it red
Rhino 8 SR13 2024-10-8 (Rhino 8, 8.13.24282.10001
i dont have time to investigate. few notes:
geometry is polysrf inside block, clipping plane is set with custom depth (0)
Hi Ivan -
Note that in this case, the intersection will always be a point.
But, yes, the point should probably be visible.
RH-84279 Display: Mark Intersection As Point
that posted image was the result of clipping plane, i think the intersection lines should be red according to settings.
That picture would have been nice to have had…
Your image of the settings for intersections is for intersections between the objects themselves, not with a clipping plane.
The intersection with the clipping plane is set in the section style.
Thank you i was not aware of that. I knew that section style dictates that but i thought that setting in display mode overrides that somehow.
