Rhino7 is not responding after launching it
Rhino7 is not responding after launching it. Downloaded and installed the setup from rhino3d. Tried everything. Please help me out !!
Hi -
Does it launch when you start it in safe mode?
Yes, it launches.
But not able to work properly on that.
Start in Safe Mode, run the command _SystemInfo in Rhino and copy/paste the results here.
Safemode is a troubleshooting tool that blocks loading OpenGL graphics and plug-ins; either of which can cause these problems.
Safemode is Not a solution. It is a way to gain access to information needed to assess and diagnose the problem.
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Evaluation, build 2022-05-04
License details: Cloud Zoo
Expires on: 2022-08-28
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 7.9Gb)
Primary display and OpenGL: Intel(R) HD Graphics 620 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y). OpenGL Ver: (null)
Secondary graphics devices.
Radeon ™ R5 M430 (AMD) Memory: 2GB, Driver date: 8-19-2019 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
Safe Mode is enabled. Graphics device usage and OpenGL information cannot be collected.
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 8-19-2019
Driver Version: 26.20.12030.1
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 16777472 x 16777217
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
Okay your Intel and AMD video drivers are extremely old, the first thing to try is to update them. Those things need to be kept up-to-date for Rhino.
Primary display and OpenGL: Intel(R) HD Graphics 620 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: (null)
Radeon ™ R5 M430 (AMD) Memory: 2GB, Driver date: 9-2-2021 (M-D-Y).
ATTENTION:
OpenGL Settings
Safe mode: On
Anti-alias mode: 4x
Driver Date: 9-2-2021
Driver Version: 27.20.20904.4000
Z-Buffer depth: n/a
@Helvetosaur @JimCarruthers please help
Hi -
There appears to be a more recent driver available from https://www.amd.com/en/support/graphics/amd-radeon-r5-series/amd-radeon-r5-400-series/amd-radeon-r5-m430.
I don’t know. Your Radeon card is 5-6 years old, looks like you have the latest driver available, but it is really entry-level and below the 4Gb minimum memory recommended…
The Intel 620 is even weaker, but there is a later driver available, you might try that.
I don’t have any other ideas…
Hey, Thank you all for the suggestions, nothing seems to be working at the moment. Maybe there’s some hardware issue.
Make sure you are not using a docking station or secondary monitor.
You should only be using your built in monitor for this test, not plugged into a docking station, no extra peripherals attached, and plugged into power.
