Rhino 07 Not responding as soon as opened
My rhino 07 seems to freeze and go straight to not responding as soon as I open it.
I’ve been having this issue for some time now but usually clearing temp files or find a crash file has seemed to solve it.
I’ve followed the advice of other posts, opened in disabled mode and turned off plug ins. I’ve also updated my graphics driver.
Would someone be able to help?
Thank you
I’m not seeing any crash reports.
Not opening up in safe mode fails as well?
If there is an opportunity please run SystemInfo in the Rhino command line and post the result. Thanks.
Try doing a clean install of your microsoft redistributables and then Repair your Rhino install (via Add Remove Programs>Rhino>Modify)
X64 vc_redist.x64.exe
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational, build 2023-12-12
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 2-7-2024 (M-D-Y). OpenGL Ver: (null)
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 2-7-2024
Driver Version: 31.0.15.5152
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 256 x 16843008
Total Video Memory: 8 GB
D:\Rhino\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
D:\Rhino\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Rhino\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
This does not look right:
Here is mine:
If it were me, I’d download the current drivers from Nvidia, run them, click the Advanced button, and choose a “Clean” install.
I’ll give this a go too, thank you. Running through the clean install of the visual C++ too. I’ll update after following both
So it does open in safe mode. That points to Video config or Plugin
Hello Both, followed both steps and i’m back in action. Thank you very much for your help and advice!
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 2-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.52
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Z-Buffer depth: 24 bits
C:\Program Files\Geometry Gym\Rhino7\BullAnt.rhp “bullant” 1.5.6.0
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\walsh\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.17.0.12530
D:\Rhino\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
D:\Rhino\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
D:\Rhino\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
D:\Rhino\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Rhino\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Rhino\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
D:\Rhino\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Rhino\Plug-ins\Displacement.rhp “Displacement”
