Rhino6 Make2D Third/First Angle projection doesnt compute the perspective viewport as parallel
Dear all,
in Rhino 5 it used to be, that if you set your viewport to parallel, the result for computing the “Make2D” command with “4 view” option would be a parallel drawing in the “perspektive” viewport. In Rhino 6 this doesnt seam to be the case. If I set the viewport to parallel, the result will be tilted no matter what. Also in some cases the lower right viewport is missing (Havent really figured out a pattern when this happens). Is this a bug, or do you have a suggestion how to get the same result as for Rhino 5?
Best Peter
Hi Peter - thanks, I see a bug here, I’m not sure it is the same as what you are reporting but very wrong none-the-less.
https://mcneel.myjetbrains.com/youtrack/issue/RH-49527
Hello Pascal,
yes I think this is the same bug. I have updated to Version 6 SR11 but the problem is staying the same. Last week I told a friend about this bug and he tested the issue with his Rhino6. For his setup the “Make2D” command works fine with parallel views;
Hi Peter - can you please find out what service release of V6 your friend is running (SystemInfo command) ? That would help us pin down when the problem was introduced…
thanks,
Hello Pascal,
unfortunately he updated his version to the latest one (6.11) right after we tested the “Make2D” command. I guess there is no way to find out which version he was running before. All I can tell you is that he got the problem now as well;
Also I had already the same results as they are discribed here: Bug Mak2d. the command missing a view detail
Best Peter
RH-49527 is fixed in the latest Service Release Candidate
