Make 2d > third angle projection
when creating 2d > third angle projection drawings of parts, is there away to keep the perspective / isometric view of the part full size and to match the perspective view port [which I currently have set to parallel.
I used to do this in rhino 5, but has changed to a ‘snap shot’ in perspective view in rhino 6.
my current work around is to create the third angle drawings delete out the perspective drawing, then go back into my parallel view and generate a new drawing of the using the ‘view’ option.
Thanks,
Not sure exactly if you already know the feature (side panel) named views?
example:
Hi, Thanks for reply.
I am aware of it, but have not worked with that much.
I just had a quick look / play, but was unable to see how this can help with the the make 2D output settings… do you know if this can indeed change the output setting for the third angle projection so I have a full size parallel drawing of the part?
Thanks,
Andrew
Hi Andrew - we have an unsolved ticket for this issue - RH-641 (not open to the public).
I’ve added your request and a few comments to that ticket.
Thanks,
OK. Thanks for update Wim…
Regards, Andrew
HI Wim,
Just checking to see if this issue has been updated / resolved?
With regards,
Andrew
Hi Andrew,
I’m afraid that’s still open at this point. I’ve given it a bump.
Hi, could you please give it another one? I can’t say how many hours I have already lost during the last 4 years doing exactly what Andrew does - making a third angle, deleting perspective and making a parallel drawing by hand. And one more thing - the scene silhouette doesn’t work more often than it does so I disabled it completely and do th outlines by hand - I use Hatch (boundary), deselect all the hollow parts by hand, DupBorder, delete the hatches and move the borders to make2d/silhouette layer. And this workflow generally gives me what i want (or at least 10x more often than make2d itself). Maybe something similar could be used as the silhouette solver in the make2d command, which for now I believe calculates the silhouette on the 3d geometry.
Hello - Is it the relative scale or the projection of the oblique view that is incorrect?
this is what I get:
Is that what you expect?
this is what I get
this is the view i get it from
and this is what I would expect to get from this view
I Igor -
Could you please run the Rhino SystemInfo command and copy-paste the result here?
sure:
Rhino 7 SR13 2021-12-14 (Rhino 7, 7.13.21348.13001, Git hash:master @ 7696723f74a63695b3c372a89110c0ca8c78b890)
License type: Edukacyjna, build 2021-12-14
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 15Gb)
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 3-11-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\igorj\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.13.21348.13001
Hi Igor -
Thanks for that information.
I can’t reproduce this behavior here. I see that this looks like a simple example, but could you please post the 3dm file so that I can see if I can reproduce that with that model?
box.3dm (131.2 KB)
Hi Igor -
Thanks.
You have 4 viewports, of which 3 are parallel viewports and 1 perspective. Currently, this will cause the Make2D command to take the perspective viewport as the 4th view in the output, the other 3 become the regular top, front, and right views.
The workaround is to either put the unused perspective viewport into a parallel projection or just close that viewport (CloseViewport).
To change the current behavior requires a bigger rewrite of the command. This is on the list as RH-3557 and will be looked at for some future version of Rhino. I added this thread in a comment.
HI PAscal,
How are you achieving this output?
I am not getting this my end at all - its still the same as before, where I have my 3 parallel viewports and one isometric. And I still get a perspective output…
This is the model, showing my viewport panels above
and this is the output running make2d
Hi Andrew -
Could you upload your 3dm file and post the output from the Rhino SystemInfo command?
HI Wim,
Thanks For getting back…
So, I have found something… It would appear that if you set the view port to isometric SE [or whichever orientation for that matter] and you DO NOT rotate the view, it will give you a Isometric / parallel output in ‘make2d’
However, if you rotate at all the view [which I often do to get a preferred view of the object] then it gives a persp 2d output… even though it is still in a parallel viewport
I am not sure why, but for some reason I am unable to upload my .3dm file - so please see screen shot of out put results.
and here is my system info below:
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13002, Git hash:master @ aa7902c94c5aa33511e60d30f82b636be43bc85f)
License type: Educational, build 2022-03-08
License details: Stand-Alone
Apple macOS Version 12.1 (Build 21C52) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro15,3
Language: en-GB (MacOS default)
AMD Radeon Pro Vega 20 OpenGL Engine (OpenGL ver:4.1 ATI-4.7.101)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4080 MB
Graphics: Radeon Pro Vega 20
Displays: Color LCD (258dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro Vega 20 (4 GB)
Color LCD (1680 x 1050)
USB devices
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.vmware.kext.vmx86 (0298.55.94) 5E109650-1929-30E1-B1D8-62D4B795D1E4
com.vmware.kext.vmioplug.15.1.6 (15.1.6) 2DEB9F10-129F-389F-9956-BE683E44913D
com.vmware.kext.vmci (90.8.1) FEC84773-0132-3347-9199-D30BD101B045
com.vmware.kext.vsockets (90.8.0) 2293C2CE-D2D2-3655-9A0D-505E5C392638
com.vmware.kext.vmnet (0298.55.94) F3B8AFF3-D0BA-3F17-9020-8BBD3B0CFA24
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/andrewhaythornthwaite/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp/libkeyshot_rhino_plugin.dylib
/Users/andrewhaythornthwaite/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.16.22067.13002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.16.22067.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.16.22067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.16.22067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.16.22067.13002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.16.22067.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.16.22067.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.16.22067.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.16.22067.13002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.16.22067.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.16.22067.1002
Hi Andrew -
Thanks for those details!
That is reproducible and filed as RH-68016.
