I can’t open my Rhino WIP. It keeps crashing while opening it.
Here attached is the RhinoDotNetCrash.
RhinoDotNetCrash.txt (1.0 KB)
Thanks
Thanks
Please run SystemInfo in the command line of your Rhino 7 and paste the results here. Thanks.
Thanks for the reply.
Here is the info as requested.
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Commercial, build 2022-11-22
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Unplugged [87% battery remaining] ~78 minutes left
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 7-19-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\Iwan Mazlan\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
Can you try disabling the plugins Karamba and Lumion and see if the problem persists? For this start Rhino in safe mode, go to PluginManager, choose from dropdown “Plugins that do not ship with Rhino” and uncheck the “enabled” for these plugins. After that start Rhino normally.
I don’t find any karamba or lumion inside the PluginManager.
Attached are the pictures of the available Plugins inside.
It’s opened and I need to open the safe mode in Rhino 7 and disabled the Plugins there. Due to these actions, I can’t synchronise the Lumion from rhino 7 anymore (until I enable the plugins again).
Karamba is still working in Rhino 7 & Grasshopper.
Thanks for the help
Does this mean your Rhino is working normally when you disable the Lumion plugin? If so, did you look if there is an update available for that plugin?
Yes, I did install the newest version of Lumion Plugins from food for Rhino, but it is still making the Rhino not respond and crash.
Hi Shazwan -
Please see the Lumion contact information on that Food for Rhino page to report this issue to them.
Thanks,
