Hi @stevebaer, @will,
Cross post from New Mesh Intersection Milestones
What version of Rhino common does compute use? Will the new mesh tools be exposed here? When?
Compute uses Rhino 7 WIP directly. It is built with the Rhino.Inside technology which is Rhino 7 only.
@scottd Wow great! So feasibly I could use this in rhino 6 as a fall back option when a mesh trim fails? I do a lot of these in a production environment so I need a stable version but the mesh trims have been giving me a headache!
Sure, that sounds possible as long as you can detect that a mesh trim failed
@wattzie you can query the specific version of Rhino that’s running on our example Compute server via https://compute.rhino3d.com/version
Edit: I’ve just updated it to use Tuesday’s WIP (7.0.19330.11335)!
