I was just wondering what the production status of the compute.rhino3d 8.x branch is? It appears some things have moved / changed, I see a lot of commented methods / calls in the repo. It seems like there’s some new paradigm on how to get a copy of the ComputeServer client file, through the client generator tool perhaps?
I’m mid development on a system that was developed against Rhino7, probably 2-3 months out from production deployment. I’d love to have my first rollout be against rhino 8 (particularly due to the .net hosting enhancements), but is the compute infrastructure for V8 considered stable / ready for production? Is there a plan for when documentation will be updated on usage, or am I just looking in the wrong place?
Super excited to get to use all the new V8 hotness!
The Deployment Guide for Production Environments for Rhino.Compute was updated a few weeks ago to work with Rhino 8. If setting up a new VM, I would recommend using the new Rhino 8 bootstrap script and it will install everything using the latest 8.x branch. We don’t currently have a “migration” script to transfer a VM setup for Rhino 7 over to Rhino 8 although this could be done manually. Still, I think it would be best (if possible) to leave your Rhino 7 setup as it is and spin up a new VM with Rhino 8 to do your testing.
Everything should work in Rhino 8 Rhino.Compute as it does in version 7. Some of the new data types that were added in GH1 for Rhino 8 are not yet supported, but we are working on updating Rhino.Compute to handle these new data types. I don’t yet have an update timeline as to when that will be working, but it is under active development so hopefully not too long. Does this help?
Thanks so much Andy, helps a bunch. So if I understand, I should be able to leave everything the same as it was on the client/caller side when calling v7, but just point it at Rhino.Compute instance hosted by 8.
