Rhino V9 Issue. Can't switch Display mode during Fillet Surface operation
I’m seeing an issue with Beta, which is not there for V8.
During Fillet Surface command (could be others as well) I can’t switch to, let’s say, Wireframe by using Ctrl+Alt+W combination. It’s working for V8, as I mentioned.
Are you seeing it?
This is probably related to this topic (see below). There were recent changes for the preview in the FilletSrf command, and what you are seeing and what is reported below needs to be tuned up.
RH-97261 is fixed in Rhino BETA
@Screamer Please try the latest BETA version. I have not been able to reproduce what you reported, before or after fixing RH-97261. When I press Ctrl+Alt+W during FilletSrf, the preview immediately changes to wireframe.
If you still experience this, please help us reproduce the problem by including a step-by-step description and a file for which this happens. And include the output of SystemInfo too.
Hi @menno ,
Unfortunately, the lates Beta gives the same result.
Here is my SysInfo.
SysInfo
Rhino 9 SR0 2026-8-11 (Rhino 9 BETA, 9.0.26223.12303, Git hash:master @ 535bf21f011dc805eafa540606c59272f4f15b11)
License type: Commercial, build 2026-08-11
License details: Stand-Alone
Expires on: 2026-09-25
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 5-7-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 6\Plug-ins\DATAKIT\Rhino6_Import_x64.rhp “Datakit_to_rhino6”
C:\ProgramData\McNeel\Rhinoceros\packages\9.0\Grasshopper_Gold_Tools\1.0\Grasshopper_Gold_Tools.rhp “Grasshopper_Gold_Tools” 2.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Here is also a video.
Ok, I have filed a separate ticket for this. RH-97782.
I think I see what is going on. It looks like you have shortcuts set up that run _WireframeViewport and _ShadedViewport, at least those commands are echo’d to the command history window in the video.
The out-of-the-box shortcuts for Ctrl+Alt+W and Ctrl+Alt+S are:
_SetDisplayMode _Wireframe and _SetDisplayMode _Shaded, respectively.
Like you, when I run _WireframeViewport during a command it does nothing, while running _SetDisplayMode _Wireframe does change the display mode.
My advice is to update your shortcuts to use _SetDisplayMode <mode>
Hi @menno ,
Sorry, with the updated shortcuts I have the same result.
@Screamer
I have no idea why the command transparency is no longer working for you… All kinds of testing here shows it to be working.
What if instead of using the shortcut keys you right-click the viewport’s title bar and select a display mode from the dropdown (i.e. Wireframe, Shaded)? Does that work?
I’m just trying to see if the mechanism for command transparency is failing in general for you… And is it only with FilletSrf? …or does it fail with any command? i.e. Start drawing a sphere, and see if you can change display modes after you’ve placed the first point.
Thanks,
-J
Hi @jeff ,
Just tried some ideas you’ve proposed.
While FilletSrf I can switch display mode (DM) by clicking on the title of a viewport. This works.
Sphere command also allows me to switch DM with keyboard shortcuts.
Both FilletSrf and ChamferSrf are not working with keyboard.
The reason, I believe, is because of a dialog window popping up.
But for example Rebuild with a dialog works fine for me. I can switch DMs while having a command’s dialog running.
So my assumption is, there are some dialogs interrupting my attempts to switch the DM using keyboard. Please try to dig this way.
@Screamer What is the exact version of Rhino you’re using?
Just run SystemInfo in Rhino and paste the results here.
Thanks,
-J
Never mind, I see you already did that above.
Thanks,
-J
@Screamer I’m coming up empty here… no amount of different combinations I’ve tried can I get this to not work.
Looking at your videos more closely I did notice that the SetDisplayMode command is not actually getting run, it’s simply providing “input” to the FilletSrf command, which that command just ignores since it doesn’t recognize it as valid input. This tells me that wires are getting crossed somewhere in the command line input and command processing.
What happens if you change to the older command line?
Run TestEtoCommandUI and select Legacy…then restart Rhino.
…I’m just speculating at this point, that the new command line parser is missing/dropping something here, and for some reason, only on your system.
Thanks,
-J
Also, I would temporarily disable any 3rd party plugins you might be running, to rule them out. Usually when a user can produce something that we cannot, it’s some 3rd party plugin they’re using that we’re not that’s getting in the way… I did notice something called “Grashopper_gold_tools”… and possibly others.
Note: If switching to the Legacy command line still does not work, please remember to switch things back to use Eto.
Thanks,
-J
Hi @jeff ,
Thanks for looking into this.
Unfortunately, Eto/Legacy didn’t help.
I also disabled any side plugins and restarted Rhino - nothing changed. Same issue.
I also unplugged my Space mouse - same result.
So, here are some observations:
  1. FilletSrf has both dialog and busy command line. Switching doesn’t work for me.
  2. Rebuild has dialog, but command line is not involved - Switching works.
  3. Line has Command line involved, but no dialog - Switching works.
Any ideas based on this?
As I mentioned in my 1st post - V8 works fine. Could you compare V8 vs V9 in changes regarding this issue?
Maybe its not working because its not being used..
It does not work if you don’t include the single quote character at the beginning.
_WireframeViewport
does not work
'_WireframeViewport
does work.
does not work
'_SetDisplayMode _Wireframe
does work.
It is working here… my statement was aimed at @Screamer … I have no idea why it’s not working for him.
-J
I can confirm. This single quote addition works for me!
Thank you.
I’m now wondering why your macros for CTRL+ALT+XXX didn’t have this to begin with? All of mine here do. The single quote (apostrophe) is what allows transparent commands to be nestable.
Did you change or import your keyboard macros from somewhere else? Can you provide a screenshot of your keyboard macros? Options->Keyboard. All of the transparent commands should have an apostrophe in front of them…
-J
Note: The reason I want the screenshot is because…
I can understand how you missed the ’ when writing your own macro… But all of your CTRL+ALT+XXX macros should all have the ’ … if they don’t, then you either edited them, or they got lost in some import process, or possibly in some porting process.
-J
