I need to use Rhino 7, but is hard to find a good GPU for a right price nowdays. So I found a refurbished AMD FirePro W7000. Rhino - System Requirements says:
at least 4GB memory
at least OpenGL 4.1
Still a video card that’s not getting driver updates anymore is not a good idea. It’s also TEN years old, and I don’t think was ever actually anything to write home about when new, virtually anything “new” is going to be better. GPU prices have begun to drop…
Don’t bother with a Quadro or FirePro, just get the best ‘gaming’ card you can find. When you want to spend $10K to get 5% better performance, fine get a Quadro, otherwise they’re a con.
l’ll buy a refurbished workstation, so all configuration above are under 1k.
A new workstation will be expensive and I can’t get it for monday.
Gaming cards are more expensive at the moment.
I had an AMD W7000 in my original workstation build. I have replaced by a later and much less expensive Vega 64 card that was half the price of the W7000 and while even that is not current tech my any means, it’s considerably faster than its predecessor. I would recommend getting a current inexpensive gaming card that will give you far better performance and likely have at least 8 GB of memory.
