Rhino V7 crashes when trying to change render properties
My new V7 crashes often and every time I attempt to even look at rendering properties.
Here is my system info:
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.11001, Git hash:master @ 2f08cf516ffc716c4c4a369abf7625798ef79bca)
License type: Commercial, build 2021-01-12
License details: Cloud Zoo
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 12-4-2020 (M-D-Y). OpenGL Ver: 4.6.14757 Compatibility Profile Context 20.12.1 27.20.14501.28009
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 12-4-2020
Driver Version: 27.20.14501.28009
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.20.0
C:\Users\Rob\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.4.1\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.4.1.0
C:\Users\Rob\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ProRender\1.0.0.0\ProRender.Windows.rhp “ProRender” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21012.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21012.11001
C:\Users\Rob\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2020.12.7.446\SectionTools.rhp “SectionTools”
Please try
Not exactly sure why your method seems to work but I can’t thank enough for allowing me to get through a complete session with V7! While there seems to be this bug and perhaps more, this release is truly amazing and require for this old Pharticus Anteequs a bit of a learning curve. I shall try not to howl or bark too much while this ol’ dog gets through all of that. I’m attempting to create in SubD a center console that is perhaps a bit more interesting that the pedestrian BOS that I’ve put on this otherwise alluring design…see attached. Cheers and thanks, Rob
From Rob Ladd of Robb Ladd Yacht Design
I believe I have a fix for this. It should be available soon in a 7.4 build. I’ll send you a version to test in a private message once it is available.
Many thanks, Nathan. I like “Jesterking” mine is “Pharticus Anteequs” borrowing from grade school pig Latin!
Get BlueMail for Android
My nickname jesterKing is from my Counter-Strike gaming days, the original CS version. It stuck through many more games into my Blender 3D development where much was done via IRC.
Yo, jesterking, well done and look forward to that release. Cheers, Rob Pharticus Anteequs Ladd
RH-62353 is fixed in the latest Rhino 7 Service Release Candidate
