Viewport crashes
Hi all,
After updating my graphics drivers today, I’ve been experiencing recurring issues. Closing and reopening the file, the issue is still there. Although using an older file temporarily resolves the problem, it reoccurs after a few hours. I’ll try to install the old drivers. Has anyone else had similar issues? Any advice would be appreciated. Thanks!
Hello- can you please run SystemInfo in Rhino and copy/paste the results here?
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Studentenlizenz, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 12-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.56
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-5-2022
Driver Version: 31.0.15.2756
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Paul\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.17.0.12530
C:\Users\Paul\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Users\Paul\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.3.0\7\Fologram.IO.Rhino3d.Win7.rhp “Fologram for Rhino” 2020.3.3.0
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Users\Paul\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.36.23346.16351
C:\Users\Paul\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Hello- I would do two things - 1. Update the Nvidia driver to the latest from the NVidia website (with Rhino closed) . If that does not fix it, in Rhino, open Options > Plug-ins page and disable all of the plug-ins listed under ‘Plugins that do not ship with Rhino’ in your System info. Close and re-open Rhino - is that any better? If so, load these plug-ins one or two at a time until you see, hoipefully, which plug-in causes trouble.
Thank you, I’ll try that.
I downloaded the latest Nvidia drivers. If I now open the broken file, Rhino immediately closes. I’ll continue working on the older file and keep you updated if the errors recur.
Hi Paul - I’d suspect a plug-in here…
