I am trying to copy and paste items in rhino but its not working, I keep getting this message when i try to copy/ paste
Write3dmViaTempFile() - Unable to lock global memory block.
Hello - please run the SystemInfo command in Rhino and copy/paste the results here.
thanks,
Hey Tala,
I have the same issue. Were you able to solve the problem?
Best, Kara
Hi Kara - are you using V5 or V6? If V6, please run the command ‘SystemInfo’ in Rhino, and post the results here. If V5, are you using any plug-ins that are not default ones? If so what are they?
Hi Pascal, hello Tala,
I just solved the problem.
Apparently my driver was not up to date. After an update of Windows everything worked normally again.
Thank you anyway!
Kara
i am facing this prob for the first time. i am using rhino 5. i read the above conversation and checked all the points but i am still facing the prob.
kindly help.!
