Rhino to ANSYS workflow (export solids and rebar)
Hi
I am trying to export geometry to ANSYS for calculation, that has solid polysurface walls/slabs and rebal, that are currently set as lines. I export to STEP but lines are missing. What are possible solutions to transfer rebar data? I am not very familiar with ANSYS, I just have to prepare file and hand over to ANSYS specialist. Is giving volume to that lines the only way to export them& If so, should I cut them out of a slab?
If you set your geometry node to work with spaceclaim, you can import the 3dm file itself without much trouble.
If i am not mistaken, step files don’t include curves, if you need to convert you would need to use IGES filetype.
However, I really recomend using SpaceClaim to import the 3dm file since you can even have the dynamic link active and update the geometry in rhino and reimport in space claim without much trouble
