Rhino Thread Tool
Does Rhino have a thread tool like Fusion 360 or something similar to model threads?
I haven’t used BoltGen, but perhaps you can use it and finally cut off the parts you don’t need? (if bolts are not what you intend to draw)
// Rolf
As Rolf stated bolt gen is a great free tool at food for rhino. I have been using it for quite awhile and I think it is wonderful.
Hope this helps … Danny
I tend to go to McMaster-Carr and find the bolt size and thread type I want and download the STP or Solidworks file and import it.
If you make something that gets 3D printed then you’re threads might just need to be run with a tap / die of the correct size and you can then use standard hardware.
