Hi All
Thanks in advance for any tips and tricks
I’m trying to export a Rhino Layout that have text fields into CAD but they come in empty.
Inside the block in cad you can see it is a text field but the text can’t be found anywhere
Wonder if anyone has faced this issue.
Hi Nicolas -
Round-tripping text fields via the DWG file format appears to be working fine in a quick test here. Please provide both the output from the Rhino SystemInfo command and a 3dm file that you are having issues with. -wim
SystemInfo
Hi Wim
Thanks so much for this. I found a workaround. But it would be amazing to get the layouts to work. We do a lot of exporting to CAD for fabrication.
Let me know is you want anything else to try and replicate the issue.
Thanks!!!
SystemInfo.txt (2.9 KB)
Rhino Layout.3dm (149.1 KB)
CAD Layout.dwg (29.8 KB)
