Hi there. After using Lands, Rhino now takes several minutes to save the file. It seems that the “Packing support file” functions is causing the snag. is there a way to disable this function?
Thanks!
Thanks!
Hi, what do you mean with “Packing support files”? Do you mean checking the “Save Textures” option on save dialog? Does the problem occur with a particular 3dm file?
To access the save dialog box you must chose “Save as…” instead of just saving on the current filename.
Aha! Thank you so much Albert!
