I like the lighting and colors in Rhino Render, does anyone know how to achieve this in Keyshot?
00.3dm (13.0 MB)
what more would you expect from a different render engine which should look the exact same? why not just using rhinos output?
Using Rhino Render is too slow and not as clear as Keyshot
you post an image of a shaded object which needs zero render time and claim its too slow, that does not make any sense.
maybe there is a misunderstanding? what exactly are you trying to replicate?
with ViewCaptureToFile you can ouput the image directly into a transparent png for further use no rendering needed, quality looks good to me?
Speed in rhino render is directly connected to your machines hardware. Can you please run the systeminfo command in rhino and post the results here?
ânot as clearâ
This should not be the case, can you show an example of rhino vs keyshot on the same model so we can figure out what you are seeing? Itâs very likely you just need to change your sample count in rhino to run a bit longer, or enable a denoiser.
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Corporate, çćŹ2022-07-27
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 8-14-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.13
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2023
Driver Version: 31.0.15.3713
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShotRhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.5.0.0\KeyShotRhinoPlugin\KeyShotRhinoPlugin.rhp âKeyShotRhinoPluginâ 1.0.0.0
D:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.21.22208.13001
D:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
D:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp âRhinoScriptâ
D:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.21.22208.13001
D:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp âLegacy Rhino Renderâ
D:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.21.22208.13001
D:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
D:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
D:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.21.22208.13001
D:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.21.22208.13001
D:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
D:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
ok, alot to unpack here.
can you post your file? I may be able to help you out with this to get better results.
