Help for the love that all is holy. Trying to render a very slow file, and now suddenly I’m getting that wording in my render window. I have it set to 500 samples. I’m drowning today trying to just get renders out. @pascal or anyone else out there that can help in real time? Thx
EDIT: I did just realize I allowed Rhino to update to 7.1 b/c 7.0 was going really slow. But maybe now it’s going slow AND not rendering?
Uninstalled and Reinstalled. Working again. But slow.
Morning, thanks for your attention to this, and apologies for not being able to send it last night. I’m happy to send the file to that non-public email for review. (There are - unfortunately - Sketchup assets in it, but I don’t see why it should slow the system down and/or effect rendering)
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-24-2019
Driver Version: 26.21.14.3200
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.0\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
On the contrary, sketchup files are often very very messy with masses of (to Rhino’ws way of thinking) stupidly nested blocks. Are there skp trees and such in the file?
No, there are a cple 2D “trees” and a couple bldg facades. Plus a 2Mb truck but I’ve tried bringing things in both as nested and referenced to no better performance.
Yes, there were a bunch of Blocks within the truck model. I exported out only the Rhino geo I needed, and rebuilt a couple skp objects in Rhino, then deleted the skp. Saving works a lot faster now. RenderMode is still completely unusable in this model. Again, happy to share the file privately for review.
Yeah that’s the file without the truck - just has the essentials. Don’t know why it’s missing materials. Fine on my end.
Yes, it works just fine now in Cycles Render (after having reinstalled) but it’s completely unable to use “Render” display mode. Barely moves. Even when I’ve lowered all the shadow options. Could you check it for that on your end, please? I’d appreciate your thoughts.
Ah will send again with them tmrw morning. They are the only skp left in there and I giess you could consider them complex. I really don’t know. They’re not just boxes.
Sent the file again. Also, something that used to happen just happened again: When I went to my Layout sheet, my text disappeared - I used tohave to select everything, cut and paste, and it showed up again. This time I tried it, and still no text. Bug?
Thanks for looking at all this. Little frustrating.
EDIT: Ah, so this is weird. Figured something out - Text that’s GROUPED with other geo (bubbles, other text, elev markers, etc, has disappeared. Text NOT grouped is still there.
