Rhino Render Unable to make "Rhino Render" the current render plug-in
Hi, I have not been able to use rhino render. Everytime I try this appears:
Plug-in name or ID ( Rhinoceros ): 5dc0192d-73dc-44f5-9141-8e72542e792d
Unable to make “Rhino Render” the current render plug-in
I do not have another rendering tool.
what do I do?
All the best,
Armando
Check under Tools > Options > Plug-ins that the Rhino Render plug-in is loaded, along with other plug-ins with Render in the name (Render development kit). Does it work better then?
Thank you. It works now
I think this video might be used if you are using Rhino for rendering.
Basically, rendering (via Viewport Capture) using Raytraced Mode viewport maybe better than the default Rhino Render.
Note that in v7 Rhino Render == Raytraced.
Wow… thanks Nathan. That is great news.
