Hello!
I Have Rhino 5 the last V…
When i push the render button:
“Unable to load render plug-in, render command not available”
I have the original version i got from the website…
Win 10
##can someone help??
thanks!
Hello!
Win 10
thanks!
That sounds like the Rhino Render plugin is either not present due to an incomplete installation or can’t load due to Rhino 5 being an expired evaluation. Look in Options>Licenses within Rhino to see what license Rhino sees on the your system first.
You might also want to download the latest version as well from http://www.rhino3d.com/download
If the original one you mention is an older service release this may also be a factor.
