Rhino pros for hire?
Not sure if this is the right place to post this. If not, please move. Thank you.
Anyways, I’ve been getting a daily headache with a guitar neck I modeled a few years back and been trying to update it. For some reason I’ve came across a ton of issues lately. Can’t get surfaces to match the curves, lots of edges that don’t match to name a few.
The model has some complex areas and those are mostly fine but when looking up close you can see there’s something missing. I decided rather than waste peoples time with questions maybe I’ll just pay someone to do it right…
Thanks in advance!
Hi…,
sorry I can’t support you, but perhaps you try it again with the new SubDs in Rhino 7, and 8:
Here a SubD guitare tutorial, and more SubD tutorials:
Good luck!
Michael
Thank you, I’ll definitely check it out
Hi, I could take a look at it for you (I’ve actually done some guitar work recently - both bodies and necks).
actually posting your modeling issue here is a good thing so that you and others will learn
I can probably help you, sent a PM
I’m interested.
Pls contact me on ar.keshavanarayan@gmail.com or on https://www.linkedin.com/in/keshava-narayan
