I’m compiling a rhino plugin for windows. Everything seems to be ok, when debbuging there is no problem at all and Rhino loads it apparently with no problems: no errors.
The thing is, I can’t find my command in the command list (intellisense), and when I check PlugInManager my plugin is intalled, loaded but it doesn’t any command.
That is the problem. I’ve defined a command in VS, and while debugging I have no issues.
The plugin (and the command) are loaded perfectly.
When I try to load it directly in a new Rhino session, I can’t see any command.
Sure, I’ve even tried to “unistalling” it by deleting it from its current folder and using a new one, just to check that the git folder wasn’t the problem.
But yeah, I have just one RHP file…
