Rhino Plugin - hidden command appears in toolbar
@eirannejad I’ve made a plugin using the ScriptEditor, marking a command as Hidden, but the command appears in the plugin toolbar:
Is this expected? If so, how can I hide the command from the Toolbar too?
If you truly do not want people to know about them, or to be able to use them, you will likely want to add your own security within the command.
I’m not sure about Toolbars, so I’m curious to hear McNeel’s response on this.
Hi @eirannejad, I’ve just compiled an updated version and the status of commands (type and icons) is inverted:
Clicking the button executes the GH_AssembleRh command (it’s not just a name mixup)
Oops. I make sure they are not included.
RH-84578 Hidden published commands are shown in toolbar
RH-84578 is fixed in Rhino 8 Service Release 14
I’m sorry to report that this is still happening in the latest SRC
2024-11-22 12_19_55-Rhino Options
This was just compiled in that SRC:
Another command is marked as Normal, but it’s not appearing in the Toolbar
