Hi all,
is there a way to create a hidden plugin command, i.e. a command that does not show up in auto-completion?
Cheers, Alex
Hi all,
Cheers, Alex
In RhinoCommon, use the CommandStyle attribute.
[CommandStyle(Style.Hidden)]
public class MyCommand : Command
For C++ check the base class constructor:
Description:
For each class derived from CRhinoCommand, there is only a single
static instance that exists in the .CPP file where the class is
defined. No other instances of a class derived from CRhinoCommand
should ever be created.
Paremeters:
bTransparent - [in] true if command is transparent and can be run
inside of other commands.
bDoNotRepeat - [in] true if command should not be repeated.
pPlugIn - [in] if command is part of a plug-in, the plug-in pointer must
be passed here. (This is automatically handled by the plug-in
wizard.)
bTestCommand - [in] true if command is a "test" or debugging tool
that should not be part of the commercial release.
CRhinoCommand(
BOOL bTransparent = false,
BOOL bDoNotRepeat = false,
const CRhinoPlugIn* pPlugIn = NULL,
BOOL bTestCommand = false
You want to set bTestCommand to true.
for vb.net it works like this: ::
<System.Runtime.InteropServices.Guid("00000000000-000000-000000000"), Rhino.Commands.CommandStyle(Style.Hidden)>
for multiple usages as in Scriptrunner you can do:
Rhino.Commands.CommandStyle(Style.ScriptRunner or Style.Hidden)
Just a note, don’t use an empty Guid as an attribute for your command. I’m sure this sample was just for illustrative purposes
It works, great, many thanks for your help, I had read the documentation but it was not apparent to me that a test command would be hidden from command completion.
