No matter what I do my Rhino never prints. This is a major problem as an architecture student because this is how I make diagrams. With a combo of 3D objects and vector lines. What should I do? Even simpler images really struggle to print.
What “PDF printer” are you using? Adobe’s can often take literal ages.
I believe when the print window shows up its “Rhino PDF.” How do I check? That could be wrong. But before it used to print things like this no problem.
Okay well how long have you tried letting it work? “Not responding” just means it’s busy working.
Can you run SystemInfo and post the results?
It runs for at least 10 minutes, but I have not waited longer because I usually try to find a different way to print it and close the program.
This is my system info:
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Educational Lab License, build 2024-10-08
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [87% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-21-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-29-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.80
Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-29-2025
Driver Version: 32.0.15.8180
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.9.0.495
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino8.rhp “ClimateStudioRhino8” 2.0.9112.15116
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
You Rhino can certainly stand to be updated.
Someone would need to see the file to tell if there’s anything funky in it.
So you’re saying it needs to be updated? How do I update it?
Go to help→check for updates….
Yeah I just updated. Did not change anything.
Well it’s hard to tell anything more from here, might need to do a chat with tech support. You could just for fun see how long it takes it to eventually get to something.
Hi Maher -
It sounds like something messed up your machine at some point.
I’d try a clean install of the latest drivers for your RTX 2000.
A recipe for doing so can be found here:
If that doesn’t help, I’d disable those plug-in and see if that makes a difference.
