Rhino opening every file as read only?
running v6 SR27, i think i just updated within the hour, all my files are opening as read only now.
Hello - if you open a file from the desktop - does that open read only?
yeah, it does
Hm - what message do you see, if any, as you open? Can you make a screen shot of that?
ERROR
EDIT: oh sorry, that’s the error for the attempted save. i get no warnings when opening the file
Hello - if you find that file in Windows Explorer, and look at its properties, is it marked as read only by Windows?
it’s unchecked
A couple of things before I call on the bigger brains - are you logged into Windows as Administrator? Does anything change if you right click on the Rhino icon and choose ā€˜Run as Administrator’? And, I assume but just making sure, Rhino is the only affected program? You can save from say Notepad or something?
logged in as admin, same behavior with running rhino as admin, and it’s the only program that is having the issue. i’ve even rebooted twice.
@kleerkoat - if you do save via SaveAs, can you then Save or must you SaveAs again?
have to use SaveAs
OK- thanks - even the smarter people than me are mystified by this behavior, so we’ll probably ask more useless questions until we get to the right one… so other saves from Rhino work as expected, Export, ViewCaptureToFile , even a Grasshopper document would be worth a try ?
Also, please run SystemInfo and post the results… you never know what plug-in might be getting involved somehow.
Does anything work differently if you run Rhino in Safe Mode, btw?
To start Rhino in Safe Mode: Windows start menu, type in ā€˜Rhinoceros’ and look for the ā€˜Rhinoceros in Safe Mode’ entry.
other saves work as intended, safe mode still read only, thanks
Rhino 6 SR27 2020-6-11 (Rhino 6, 6.27.20163.15081, Git hash:master @ 8c9f18774d0fe24946068d123d78712d7a17f847)
License type: Commercial, build 2020-06-11
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: RGILMORE
Hybrid graphics system.
Primary display: Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 4-7-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.92
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 8x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 4-7-2020
  Driver Version: 26.21.14.4292
  Z-Buffer depth: 24 bits
  Total Video Memory: 4 GB
Rhino plugins
  C:\Program Files\Rhino 6\Plug-ins\Commands.rhp	"Commands"	6.27.20163.15081
  C:\Program Files\Rhino 6\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp	"Rhino Render"
  C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	6.27.20163.15081
  C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp	"Renderer Development Kit UI"
  C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp	"PanelingTools"
  C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	6.27.20163.15081
  C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	6.27.20163.15081
  C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	6.27.20163.15081
  C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	6.27.20163.15081
  C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp	"Displacement"
  C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\ColorPicker\6.0.0\ColorPicker.rhp	"ColorPicker"
  C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\raytraced-materials\0.1.3+v6.15\RaytracedMaterials.rhp	"Raytraced Materials"	0.1.3.0
  C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\SectionTools\2019.7.29+584\SectionTools.rhp	"SectionTools"
Could you try going to the ā€œOptions/Filesā€ page and un check the ā€œEnable file lockingā€ option. When this is done try opening and saving a file and let me know if it makes a difference. I would not recommend leaving this option off as a long term to your problem but am interested to know if it affects the save behavior.
Thanks for the report and details - we can repeat this here now.
RH-59194 Files read-only if file locking is off
RH-59194 is fixed in the latest Service Release
I am having the same issue. I have the latest version of Rhino 7. I am not able to save my file.
error
Hi -
Do you have this issue with any file?
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Educational Lab License, build 2021-06-09
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp ā€œKaramba3DLicenseā€
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp ā€œV-Ray for Rhinoā€
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp ā€œCommandsā€ 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp ā€œRenderer Development Kitā€
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp ā€œRhino Renderā€ 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp ā€œRDK_EtoUIā€ 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp ā€œRenderer Development Kit UIā€
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp ā€œSnapshotsā€
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp ā€œRhinoCyclesā€ 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp ā€œToolbarsā€ 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp ā€œ3Dconnexion 3D Mouseā€
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp ā€œDisplacementā€
