Rhino on Mac won't PDF
I seem to be having issues with PDFing any drawings, I recently received a new desktop and after the switch any file i’ve gone to print and save as a PDF shows up blank. I was told to post my problem here with all of the info about my rhino. Thank you!
Software information
Software versions
Rhinoceros version: 5.4.2 (5E411)
Rhinoceros path: /Applications/Rhinoceros.app
IronPython version: not installed
Language: en-US (MacOS default)
macOS version: Version 10.14.1 (Build 18B75)
Plug-ins
/Library/Printers/hp/PDEs/hpPostScriptPDE.plugin/Contents/MacOS/hpPostScriptPDE
/Library/Printers/hp/Frameworks/HPSmartPrint.framework/Versions/A/HPSmartPrint
/Library/Printers/hp/PDEs/hpPostScriptPDE.plugin/Contents/PlugIns/SmartPrintPostScript.plugin/Contents/MacOS/SmartPrintPostScript
Third party kernel extensions
com.getdropbox.dropbox.kext (1.9.2) 839E5397-9078-30D5-B6FA-47A4D99838BD
Hardware information
Computer hardware
Hardware model: iMac18,3
Processor: Intel Core i7-7700K CPU @ 4.20GHz
Memory: 32 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Radeon Pro 580 8192 MB
Memory: 8192 MB
Screen size: 2560 x 1440
Displays: iMac (217dpi 2x)
USB devices
Apple Inc.: iPhone
Broadcom Corp.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
Broadcom: Magic Keyboard with Numeric Keypad
Broadcom: Magic Mouse 2
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-2.2.8
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
Hi Sophia,
Before trying anything else , and just to make sure, could you update to the latest 5.5? , you are now running 5.4 on OS X 10.14
Hi Jespizua,
This update seemed to fix the issue. Thank you for your help!
Great!
