I want to import 3d model to Revit and add parameters for each object in Revit.
Is it possible to import this 3d model as .ifc format by Visualarq with its IFC properties to Revit?
Thanks&Regards,
Elif
Thanks&Regards,
Elif
Hi Elif,
You can assign custom parameters to Rhino geometry (or VA objects) in VisualARQ, and export the file to IFC. This video explains how to do this: https://youtu.be/rdX7I79qTTI
That information in the geometry will be stored as ifc Properties. Revit will read these parameters as ifc properties stored in the geometry.
