Long time PC Rhino user, just opened Rhino for Mac and am lost. How do I UNDO an action? I dragged an object and wanted to move it back, but “UNDO” is shaded out and Command-Z doesn’t do anything.
Also, where is the gum ball? I clicked on the Gumball box at the top but no gum ball appears.
You’re right CMD+Z is undo on Mac. I’m not sure why yours isn’t working… does undo work in other apps?
The Gumball will require a selection to show up… is something selected? If not, something is odd on this machine. Please post all the info about what OSX version and hardware you’re using from the About this Mac dialog.
I am running OS 10.8.5 on a Mac Mini 2Ghz Intel Core 2 Duo w 4G RAM. Rhino for Mac 5.0.1 (5A858) Seems to open and run Rhino handily.
If I draw a line, then look under the Edit menu, Undo is shaded out, and Cmd-Z will not work to delete it or to un-drag it. If I draw multiple connected line segments, I can get rid of individual segments using Cmd-Z as long as they are still “live”.
Thanks for the extra info. I’m stumped… @dan@marlin any ideas? I started hunting for control of the undo stack count but am not seeing a setting to check.
