Just wanted to report a bug in the latest Rhino for Mac update where when I try to undo a command, let’s say after moving or deleting an object, the command line says nothing to undo.
Here’s a video, I used keyboard commands to delete and undo and visible on the command line.
Thank you.
Version 7 (7.13.21313.11002, 2021-11-09)
Does this also happen in a new file from a factory-default template?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Hi @wim
This was a new file from a factory default template, though the issue didn’t start until the previous Rhino update was installed last week (just updated to the latest Mac only SR today).
It’s functioning fine after restarting Rhino and will post SystemInfo when the issue returns. Maybe the latest SR inadvertently resolves this.
Many thanks
