Does anyone use Unreal Engine ? On a Mac the Datasmith function doesn’t seem to exist within UE. What is the workflow to get model from Rhino Mac into UE ?
Hi Miles - In case that helps, Unreal has published a Twinmotion Direct Link plug-in for Rhino for Mac.
Also, while there might be users here that use UE, you might want look at an Unreal user forum as well.
Did you check the Plugin Manager in UE? On Windows you have to load the Datasmith CAD plugin and start a new project I believe to see the menu.
yes been using the TM direct link for a while
I don’t believe there is a Datasmith connection with UE on Macs
