Hej!
Im having issues with my Rhino 8 linetype scale and appearance of dashed lines.
My dashed lines are not visible in Layout view while they are perfectly visible in the normal Top view. No matter if in Print Display or not or however high or low i put the Linetype scale…the dashes dont appear. (I am in a 1:500 drawing) Is there any fixes to this?
Hej Nora -
Please post a 3dm file in which you are seeing this.
Dashed Line Test.3dm (1.2 MB)
Hej Wim! Here you can see the issue.
Hej Nora -
Your dashed line is defined as 2700, 6350 mm. That won’t fit on a A3-sized piece of paper (the layout). You need to define the linetype as something that you want to see on paper and then scale that by some factor to also see it in model space.
Ahh thank you so much! Its fixed.
