I wanted to reach out and ask if someone might know a few settings to optimise modelling with Rhino.
I just built a new PC, with a 32Core AMD Chip and the fastest SSD available. Paired with a 2070 Super NVIDIA graphics-card and lots of fancy high performance components. Rendering works very fast, however the modelling seems unusual slow and none of the available resources seem to be used.
Any Ideas? Really appreciate some insights.
Best regards in the meantime, Aria
Dear Willem,
thank you very much for responding this quickly!
I think I have found the issue, its when the Vray plugin is activated it seems to slow down the viewport and the interface dramatically. I reinstalled Rhino and Vray, but seems to occur again. I even downloaded an older Vray to see if this happens too and it does.
I updated the Nvidia driver too and restored all the graphic-card setting to default again.
Uninstalling or deactivating Vray does the trick. But in the same time, I need Vray for my everyday work. Is this a common problem?
Best regards and thank you for your time already
Aria
