thanks , it works
May i know how to use this input (Creases) , i have created that ramp by points , but i want to know how to use this input correctly , thanks
Here is a good illustration of how the Creases are used to turn Fold lines to Split Lines
With Creases these are now Split Lines
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-179EE24F-5F74-432E-9625-6924AD17BD2D
Hi Japhy,
I’m getting some unexpected results when trying to align a slab to an existing topo surface. Could you take a look and let me know what I might be doing wrong?
Thanks!
Host Shape_Modified Slab to Topo Surface.gh (338.8 KB)
Sure thing, what Revit Version are you targeting?
Hi Japhy, I was using Revit 2024 and Rhino 7. Thanks
Hi Josphy, I’m just wondering if you’re able to replicate the issue on your end, or if you’ve identified the reason why some floor sub-points aren’t attaching to the desired topo surface?
