I want to get access to the Revision Schedule information, I can get to the schedule but I get stuck there.
Any hints?
Thanks
Thanks @Japhy. I am after the information shown on every sheet.
I found out there is a “Sheet Revisions” node ![]()
The only thing I can’t retrieve is the Revision Number (P01, P02, P03, P04)…
Any idea?
Thanks
Thanks, let me try to explain further.
I would like to read the revision numbers of each sheet. Am using the “per-sheet” numbering, not the “per-project” one.
Thanks
I tried the suggested solution but had no luck.
This one might be tough, its a nested view in the Titleblock family.
Typically you can get the items like so, as you see nothing is returned from the nested view. I’ll keep poking at it.
Hi, I will run you through this one to the best of my knowledge… As you know there are two ways to setup revision numbering inside Revit
Note in the following I will be using 2 sheets with same revisions assigned throughout, and only change will be “Per Project” / “Per Sheet”
OPTION 1: (Per Project)
For this method getting the revision number, based on sheet revisions is as simple as below…
OPTION 2: (Per Sheet)
Now, for this numbering option… once you change you will see that the Revision Number Parameter will change to null, and your only way to get the actual numbering on sheet is to replicate the Numbering sequence (as far as I know there is no way to get it using Revit’s API, if someone knows a way please let us know) as shown below…
