Rhino.Inside.Revit fails to load on Revit 2026.5
Rhino.Inside.Revit fails to load on Revit 2026.5 (build 26.5.0.55, released 2026-08-06).
The journal file shows an assembly version conflict on startup:
API_ERROR: Assembly version conflict in some references in RhinoInside.Revit.Loader.dll assembly
  • RevitAPI 26.0.4.0 conflicts with preloaded 26.5.0.55
  • RevitAPIUI 26.0.4.0 conflicts with preloaded 26.5.0.55
    (plus several System.* / .NET runtime module conflicts)
API_ERROR: Starting External Application: Rhino.Inside failed.
My setup:
  • Revit 2026.5 (26.5.0.55)
  • Rhino 8.31.26126.13431
  • RhinoInside.Revit 1.35.9698.15636
The add-in is registered correctly (shows in the .addin manifest log with NoError), but the External Application itself fails to start due to the version conflict above.
Is there a newer dujour/daily build that targets RevitAPI 26.5.0.55? I saw in another thread that direct dujour links are sometimes shared when the public installer lags behind a Revit point release.
Thanks in advance!
Lets get you on the latest, at least 8.32 is req’d
