I’m having trouble getting Rhino.Inside.Revit to load in Revit 2027.3. It appears in Add-Ins Manager and is enabled, but the Rhino.Inside tab never appears in the ribbon.
The Revit journal (journal.0003.txt, lines 2150–2153) reports an assembly version conflict in RhinoInside.Revit.Loader.dll during startup:
RevitAPI27.0.4.0 conflicts with the preloaded version 27.3.0.0. -
RevitAPIUI27.0.4.0 conflicts with the preloaded version 27.3.0.0.
Immediately afterward, the journal logs API_ERROR while starting the Rhino.Inside external application.
My setup:
Revit 2027.3 (build
20260907_1515(x64)) -
Rhino 8 SR36 (
8.36.26296.17001) -
Rhino.Inside.Revit
1.35.9698.15636 -
Windows 11 ARM running in Parallels on an Apple Silicon Mac
Rhino runs normally as a standalone application in the same Windows VM. I saw the same type of startup error on Revit 2027.2. Reinstalling Revit brought it to 2027.3, but the tab still does not appear.
Is there a newer daily build or release candidate that has been tested with Revit 2027.3? Has anyone reproduced this startup error on native Intel or AMD Windows? I’d like to understand whether the issue also occurs outside Parallels.
Thanks in advance!
