Rhino Inside Revit : Eto Not Implemented Exception
Hi, I had to update Rhino WIP this morning, and I get this exception now running Rhinon Inside Revit 2020. Starting GH without Rhino works ok. I checked open source repo and have code in sync with latest there.
Would you mind installing Rhino WIP from scratch (uninstall-reinstall) and test again? Seems like something is broken with the Eto UI framework.
Uninstalling, rebooting and reinstalling didn’t result in any change.
Hey @jonm
BTW Do you have the most recent version of Rhino.Inside installed from this location?
That installer seems to work. I was building from this code, https://github.com/mcneel/rhino.inside/tree/autodesk/revit/wip but seems it hasn’t been updated since early November.
@jonm Ya that’s the initial Rhino.Inside repo. Because of the importance of Rhino.Inside.Revit, it’s been moved to its own repo here
