When starting Rhino Inside Revit plugin in Revit, appears the message “Rhino license manager initialization failed with error - 200. Rhino will not run”.
But when i open the Rhinoceros without Revit it opens perfectly.
Any help?
- Check Revit. Be sure to have all the latest “hotfixes” installed.
- Check Rhino.Inside. Be sure to have the latest version installed.
Everything is installed up to date.
Hi @j.p.r.fernandes,
This use to be due a conflict with an other AddIn.
Please follow this page and tell use what you found.
