The drop down arrow for layer in Properties or Block Manager is not working? It works fine in regular Rhino, but the arrow is unresponsive in Rhino inside Revit. It happens all the time, so it doesn’t seem like just one time issue.
We’ll take a look, can you provide your about info? Thanks
[Expanded Information]
Rhino: 8.5.24072.13001 (Rhino 8)
Revit: 2022.1.5 (22.1.50.17)
CLR: 4.0.30319.42000 (4.8.9181.0)
OS: Microsoft Windows NT 10.0.22631.0
Could you please try in the latest official release?
It happens with complete new documents even before opening Grasshopper
Lets do a repair install of Rhino 8 via Windows>Add & Remove Programs> Modify> Repair
Please run SystemInfo in your Rhino command line and paste the results. Thanks
systeminfo before or after Repair?
Also, does repair change any settings? revert to default?
SystemInfo is going to tell us about your Video Configuration as well as any 3rd party plugins you are running.
A Repair Install will revert to the default settings.
I’m a bit worried if I can’t get all the settings back to what I’ve changed. Hopefully this tells you something. I’m using a laptop with two external monitors.
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [75% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4090 Laptop GPU (NVidia) Memory: 16GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 4090 Laptop GPU (NVidia) Memory: 16GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Users\lsong\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.5.24072.13001
Still doesn’t work with 3rd party plugged in turned off. To be clear, the layer dropdown in Properties panel works just fine in regular Rhino.
Also, strangely in Rhino inside Revit, other dropdowns work fine. It’s just Layer dropdown that’s not working.
This seems isolated to your environment. A few more things we can do to troubleshoot.
Test with only one monitor active.
Test with no other Revit Addins loaded. Rhino.Inside®.Revit
