Hi, I’m new to using this plugin and Im trying to import a rhino file to revit but I am getting this error message.
Does anyone know how to go about solving this?
1/32" is all that Revit will allow i believe, so best to keep things larger than that. You will have to redraw some of your geometry to accommodate.
1/256 of a foot or about 1mm is the smallest curve segment allowed in Revit.
Watch out for poorly formed curves with too many control points. This is especially true with imported geometry from other places. Usually a rebuild command will fix it.
ok thank you!
